Outlet Guide Vane and CompPy Screenshots
A project log for 3D Printed Axial Compressor
An axial compressor that is designed to be produced inexpensively by the daily hobbyist
noobsaucenoob_sauce 05/01/2017 at 22:360 Comments
I'm trying to play catch-up with what I've got and what I've documented, all why juggling work.
Anyways, I decided to attach some screenshots of my program CompPy. This is what I used to build my rotors and stators.
I'm still working on making it an executable so people without Python can run it.
The next thing I'm working on is a design for an outlet guide vane. When the air is exiting the final stage it has a swirl which is created from the final stator. If a combustion chamber was installed the most efficient burn would occur if the air was relatively straight, to achieve this an outlet guide vane is installed.
I calculated that I'll need an outlet guide vane that has 17 blades. But instead of just a regular blade, there is another and better option. In 2012 a patent was filled, (Patent Number: 8,333,592 B2 for those interested) that showed that having an outlet guide vane with a blade that had a different angle of attack about 30% the length.
I'm probably not explaining this correctly so attached is a picture. The left diagram is a regular outlet vane and the right one is with the increased swept.
So this weekend I'll work on a model and try and print it.
