Version 4.2
A project log for PewPew FeatherWing
A shield for Adafruit Feather boards with buttons and a LED matrix display, for simple games.
dehipudeʃhipu • 10/23/2017 at 23:48•2 Comments
After finding the reason for CircuitPython crashes in #µGame and getting the audio amplifier to work, version 4.1 has pretty much all the parts that I wanted to have. However, its physical layout is somewhat problematic, especially the rather large speaker smack in the middle of the board, which makes it hard to add a battery there.
So I started working on version 4.2. So far I have the following changes:
I'm still considering two more changes:
I think that 4.2 will be the last prototype, at least if everything works as expected.
davedarko wrote 10/24/2017 at 12:49 • point
Since you're free from the feather wing form factor now, have you thought about using a 32mm RG matrix and go from there? Designing might get much easier that way.
deʃhipu wrote 10/24/2017 at 12:54 • point
You... you are genius!
