The project continues.
A project log for Affordable Water Level Measuring Station
An Affordable cloud connected water level measuring station for developing countries.
jelle-kramerJelle Kramer 07/12/2017 at 14:291 Comment
It's been a while since the last update of this project. All the team members were very busy with exams, among other things. The next goal is to make the sensor work using the Particle Elektron as a microcontroller. This is quite a challenge, as there is not as much information available as for the Arduino. I will try to write as much as possible about the progress here on Hackaday and reply to all your comments and questions.
Nick M wrote 08/02/2020 at 04:09 point
which funnel did you end up using in the end?
I’m keen to replicate this in a domestic application
