Hackaday.io Hackaday.io
Sign up Log in
Plants analyzer
Analyzing plant health with near-infrared imagery
sang-ho-leeSang Ho Lee
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
940 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
  • The 2017 Hackaday Prize
View Gallery
0
940
6
Team (1)
  • sang-ho-leeSang Ho Lee
Join this project's team
  • Infragram project
  • Infragram You Tube
  • Raspberry Pi Wearable Time Lapse Camera
hardware
ongoing project
2017HackadayPrize
Related lists
2017 THP: Digi-Key Parts
Hackaday Prize Entries using Digi-Key parts
This project is submitted for
  • Design your concept
This project was created on 04/29/2017 and last updated 3 years ago.
Description
I'm interested in analyzing plant status and want to check with my technology.
So I searched 'Infragram' project which is developed in Public Lab(https://publiclab.org/) and it is work as below.
Vineyards, large farms, and NASA all use near-infrared photography for assessing plant health, usually by mounting expensive sensors on airplanes and satellites. At Public Lab developed a Do-It-Yourself way to take these kinds of photos, enabling us to monitor our environment through quantifiable data.
Their technique uses a modified digital camera to capture near-infrared and blue light in the same image, but in different color channels. We then post-process the image (using Infragram.org) to attempt to infer how much it is photosynthesizing. This allows us to better understand and quantify how much of the available light plants are metabolizing into sugar via photosy
Components
  • 1 × Raspberry pi zero Main Controller
  • 1 × Blue filter https://www.raspberrypi.org/blog/whats-that-blue-thing-doing-here/
  • 1 × Raspberry Pi NoIR Camera Board - Infrared-sensitive Camera https://www.adafruit.com/product/1567
  • 1 × RESISTIVE touch 2.8" PiTFT https://learn.adafruit.com/adafruit-pitft-28-inch-resistive-touchscreen-display-raspberry-pi/easy-install
Build Instructions
Collapse
  • 1
    Step 1
    Wifi Raspberry Pi Touch screen camera
View all instructions
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
A better light source for scanning color negative film
Project Owner Contributor
Scanlight
jackw01jackw01
Official Hackaday Prize Entry
Cassapa is a system to help aiming at pool games. It uses augmented reality to help the player to adjust the cue direction.
Cassapa - Augmented Reality Pool Game
alexalex
Hackaday Prize 2019
FiberGrid is a sensor framework for robotics
FiberGrid
rand3289rand3289
The goal of this project is not to invent the wheel, but instead try apply optical filters and image processing to achieve the goal.
YET Another IR Vein Detector
narfnarf
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Plants analyzer", please tell us the reason.
Send message
Remove Member
