PaperBack: Draft Business Plan
A project log for PaperBack: A Desktop EPaper Monitor
EPaper monitor driven by either VGA or an Internet Connected ESP32.
pkPK 07/24/2017 at 06:540 Comments
I wrote up a brief business plan for PaperBack... albeit more in the form of an investment pitch.  Now I'm just a hobbyist building a product I'd love to own - but if I were to scale up, this is where I'd start; enjoy!
Executive Summary
PaperBack is a 6" secondary desktop monitor based on an ePaper Display.
In one mode PaperBack works as an Internet Connected Display.  With a second board, PaperBack can be converted into a 6" VGA Monitor.
Mission Statement
PaperBack is either an internet connected or a desktop ePaper Display.
Designed around a 6" ePaper panel, PaperBack promises lower energy consumption than a standard desktop monitor.  PaperBack has the ability to run off a Lithium Ion battery, but for static images requires zero energy to maintain a current image.
Additionally, PaperBack does not emit potentially harmful or discomforting blue light.  As some wavelengths of blue light are sleep disrupting or annoying, PaperBack should be very usable at the end of the day.
Finally, PaperBack is educational.  We've written extensively on our development process as well as open sourced all hardware designs and schematics.  All firmware is licensed with the MIT license, and everything non-physical needed to build PaperBack is available for free online.
Target Market
One of PaperBack's target markets users who display static images and text on a secondary display, such as people in the scientific and engineering communities.  Reference materials, schematics and engineering drawings pair well with ePaper and can be left on screen indefinitely without an additional power requirement.
A second target market is for users looking for an internet connected display.  Many applications are possible - calendars, weather stations, picture galleries, virtual whiteboards, info displays and more.  The nonexistent power requirement for static images is perfect for slowly changing information and informational setups.
Other Similar Products
Currently, the Dasung Paperlike is the only product we are aware of that fills a similar niche.  The PaperLike is a 13.3" ePaper Display with up to 1600x1200 resolution, and 4-Bit Greyscale (16-Colors).
It boasts similar refresh rates to PaperBack.  It ships with a number of contrast modes, some of which speed up refreshes greatly.  The Paperlike uses USB for power, and has a USB display driver - but not a standard desktop display interface.
The next version of the Paperlike does add a standard interface, HDMI.  It is not yet released.
The Paperlike is not yet widely available in the United States and the first version cost more than $1,000.  The next version (HDMI) can currently be purchased for $899.
In the internet connected configuration, there is some crossover with ePaper eBook readers.  The number of models is too extensive to list, but some eReaders have app stores and applications which target similar functionality.  We hope that superior integration in Internet Connected mode gives PaperBack the edge.
Product Sales Summary
Future Models
If PaperBack is successful, the next version should use a larger ePaper panel
The 9.7" ED097OC1 compatible ePaper Panel is an obvious next panel choice.  Although refresh rates will scale and be similarly slow (at the same relative rate per pixel), resolution increases to 1200x825.
Technical Details
These technical details are the same across modes and are subject to change as more firmware and models are added.
