Just for fun: Where this started
A project log for Serious desktop CNC mill
On its fourth revision, designed for heavy-duty use machining aluminum and possibly steel
dbtayldbtayl 04/30/2017 at 16:080 Comments
This is where the project started some 5 years ago... built from whatever was sitting in the basement. No design, just build-as-you-go. The spindle is an old Dremel held on with a hose clamp. The leadscrews were 1/4-20 threaded rod, coupled to the motors with rubber tubing. The whole machine was built out of an old tabletop.
Amazing what happens if you stick with ti!
