H-Bridge Install
A project log for Robot Panda
Robot Panda is a kids toy turned high tech. I am installing 2 arduino mega's and tons of sensors. To make a fun interactive robot.
robopandapdxRoboPandaPDX 07/27/2014 at 16:111 Comment
I do most of my shopping at sparkfun.com I found some h-bridge boards. these are well labeled and can drive 1 amp. this week i am installing 5 boards to run 10 motors for movement. hopefully i will get some programming done on it too. I will at least get a diagnostic program written so i can test all the motors.
RoboPandaPDX wrote 08/02/2014 at 16:47 point
https://www.sparkfun.com/products/9457
i bought 4 x motor drivers from the link above. ihave used these in several projects. they are awesome. It can push 1 amp which is fine for the little toy motors in the panda. i have soldered them to a board that will fit in the panda and am now soldering all the paths for the board. i would love to etch a board for these components later. so i have made all the breakouts removable. this will also help if i burn one out over the long run.
