earpods2_prototype_mirror.AIThe ai. file for laser cutting machine to cut the silicon pad for the right side.postscript - 63.42 kB - 05/01/2017 at 07:54 |
earpods2_prototype.AIThe ai. file for laser cutting machine to cut the silicon pad for the left side.postscript - 49.91 kB - 05/01/2017 at 07:54 |
earpods.3dmThis is the original 3dm file for the both sides of the Rearia earphones design.3dm - 2.98 MB - 05/01/2017 at 07:44 |
earpods2_prototype_top.stlThis stl file could be used to print a part of the shell of the left side Rearia with a 3D printer.Standard Tesselated Geometry - 5.50 MB - 05/01/2017 at 07:41 |
earpods2_prototype_down.stlThis stl file could be used to print a part of the shell of the left side Rearia with a 3D printer.Standard Tesselated Geometry - 4.83 MB - 05/01/2017 at 07:41 |
earpods2_prototype_top_mirror.stlThis stl file could be used to print a part of the shell of the right side of Rearia with a 3D printer.Standard Tesselated Geometry - 5.50 MB - 05/01/2017 at 07:41 |
earpods2_prototype_down_mirror.stlThis stl file could be used to print a part of the shell of the right side of Rearia with a 3D printer.Standard Tesselated Geometry - 4.83 MB - 05/01/2017 at 07:41 |
