Antenna Selection
A project log for CEMN - Community Engagement Mesh Network
Under served communities can benefit from the exchange of information through local mesh networks to exchange critical notifications
miladMilad 06/12/2017 at 06:560 Comments
We went over different Micro-controller options to create each of mesh nodes and some of them offer on-board Wi-Fi and Bluetooth chip-set but there could be a need to extend the Wi-Fi range.We will compare different antenna options in this update.
Omega2 and WiPy 2.0 both have UFL Connector and their Wi-Fi range can be extended by adding an external antenna.
https://www.adafruit.com/product/3340
Raspberry Pi Zero W and other versions of Raspberry Pi offer the option to extend Wi-Fi range by adding an external Wi-Fi USB dongle.
USB WiFi (802.11b/g/n) with RTL8192cu Chip-set and Ralink RT3070 Chipset work out of the box with Raspbian OS and they are the two of the most common USB Wi-Fi dongles which can be purchased in most countries.
https://www.adafruit.com/product/1030
https://www.modmypi.com/raspberry-pi/accessories/wifi-dongles/wifi-dongle-ultra-long-range-high-gain-w-5dbi-antenna
We will be looking at more options in future posts and make final decision.
