Wheels!
A project log for RepKiln
A small and inexpensive kiln for melting metals and firing clay
matt-mosesMatt Moses 03/16/2018 at 05:210 Comments
It was time to move the car into the garage, so the kiln needed some wheels to make it movable. A mobile frame was bolted together using a few feet of 1 inch X 1/8 inch angle steel, and four standard locking caster wheels. This new wheel frame went underneath the existing brick support lattice. The entire kiln was disassembled, and then reassembled using fired bricks from the bottom up. The unfired bricks are now accessible and will be fired in sets of eight until the whole kiln will contain fired bricks.
