This concept is about embedding a heater element inside the pcb design itself. Tested successfully with oshpark 2 and 4 layer designs. Rolling out to more adventurous form factors.
The big advantage is its quick and uses very low energy, which can typically be supplied by a USB-A port (for compact designs).
