Sotto Is Done!
A project log for Sotto: A Silent One-Handed Modular Keyset
The essential input you never knew you needed. Sotto is a portable, wearable, more subtle way for you to text and type on the go.
christineChristine 10/15/2017 at 19:430 Comments
Hi all!
Ready to type chorded-style?
Here's the how-to for Sotto, the one-handed bluetooth chorded keyset that writes and reads with haptic feedback.
You can see from past logs that I played a lot with different inputs for Sotto, but in the end I wanted to make something that was going to be extremely easy for any of you to build immediately, without having to go pick up specialized parts. So this final version uses stuff you probably already have lying around-- push buttons, vibration motors, wire, and JST headers.
I've posted instructions on how to get it working, but I suggest you check out this video, which will make the instructions a lot easier to follow:
