Dave's Boolean Bits
A set of 9 breadboard friendly boolean logic gates
Starting from
$16.00
prpplague has 18 orders / 1 reviews
Ships from Hurst, US
The is a set of 9 basic boolean logic blocks. they come as a single pcb that is snapped apart. the included headers can be soldered onto the pcbs or wires can be soldered directly to the pcbs. The set includes 2 AND gates (74LVC1G08), 2 NOR gates (74LVC1G02), 2 XOR gates (74LVC1G86), 1 NOT gate (74LVC1G04), 1 NAND gate (74LVC1G00), and 1 OR gate (74LVC1G32). The devices are 7400 series LVC with a supported voltage range from +1.65V to +5.5V. The set includes enough blocks to breadboard either a 1-bit full adder, or 1-bit latch, or 1 D FlipFlop, or 1 R-S FlipFlop as examples.
Ever need a single logic gate for your breadboard project? Are you experimenting with digital logic gates? Dave's Boolean Bits are breadboard friendly and easy for prototyping as well as educational! I am happy to announce that they are now available on the new Dave's Dev Lab Tindie Store! These are single gate versions of the popular 7400 LVC series. The LVC devices support from 1.65V to 5.5V supply voltage and source up to 24mA per signal which makes driving LEDs directly a snap!
View all 6 components
View all 2 project logs
nardev wrote 01/24/2019 at 10:01 point
Bravo, very nice idea.
Dave's Dev Lab wrote 01/24/2019 at 23:56 point
@nardev - thanks! i assume you are the person that asked for shipping to Bosnia and Herzegovina. I've added a new shipping rate for that on Tindie!
