Ordering the Business End
A project log for CO-AFM - Cheap Open source Atomic Force Microscope
The design of a low cost, quasi nano-scale, Atomic Force Microscope (AFM), using 3d printing and open-source software.
edward-borgEdward Borg 08/20/2014 at 04:300 Comments
Ordered an Akiyama Probe that is a self exciting probe which will not require the use of a light system in order to get the surface structure data. This will relate the surface structure data since the probe will be oscillating at a set frequency and by means of a PLL any shift in phase caused by the interaction with the surface structure will be recorded.
More details about akiyama probes can be found at:-
http://www.akiyamaprobe.com/wp-content/uploads/2009/03/akiyama-probe_technicalguide_2009mar23.pdf
