Progress!
A project log for Slighty overengineered bracket for shoeshelf
A new 3d printed bracket to replace the rubbish bracket provided by ikea to hold the shoeshelftray
ysteinØystein 05/05/2017 at 15:360 Comments
So I printed out the pieces on a delta 3d printer and a ultimaker original. I have never tested a deltaprinter before so that was fun. It turned out that mostly the design worked as intended. One mistake I made was that the spheres where to small.
I then made the spheres 3mm instead of 1mm. And printed it again on the deltaprinter.
This looks much better. I printed out the rest of the pieces and assembled it with m5 screws and locknuts:
Finally at testfit on the rail it should be mounted on:
Yay! It mounted firm and secure! This looks very promising! I made some minor tweaks and I am going to print out new brackets tomorrow.
