First PCB Etch
A project log for Landy Wiper Control
Sick of having 2 speeds for my windscreen wipers. Nothing a 555 timer can't fix!
tron9000Tron9000 08/03/2017 at 12:220 Comments
I Etched my First PCB at home using the toner transfer on magazine paper method using the PCB transfer I made in EAGLE (See files I've added):
NOT TO SCALE - DO NOT COPY, BOTTOM SIDE AS VIEWED FROM TOP
I printed it off onto gloss magazine paper, cleaned the surface of the PCB, hooked up a heated pad to a  power supply to warm the ferric cholride and aid to speed up the etching process...
...then applied the transfer to the PCB using a clothes Iron with a sheet of foil between the paper and iron surface, Iron was cranked to highest setting and pressed down for about 5mins and after a bath in water, managed to peel off the magazine paper:
Some touch-up was required with the permanent fine marker and then into the etch bath. Here's how it came out...
Hmmm....not the best really, would work if i did a little fettling. I think the issue is I am leaving the iron on for too long and the toner is bringing the paper with it and also bleeding.
Unfortunately this was the only piece of bare copper clad I had, the others have photo-sensitive resists on them, If i can get hold of some transparency and leave it out on a sunny day then I could get the same result. I have some more bare copper coming soon.
I'm going to make another attempt either using the photo-resistive stuff or the bare clad when it arrives.
