Idler_verstellerV2.stlThe part of the belt-tensioning mechanism that actually holds the ball bearing and idlersla - 154.55 kB - 09/29/2017 at 20:18 |
Idler_halterV2.stlThe mounting plate for the belt-tensioning mechanismsla - 201.60 kB - 09/29/2017 at 20:18 |
anriebsrad drehteller kreisviertel.stlThe main pulley for the turntable. 120 mm inner Diameter, so it is only a quarter of the actual pulley to fit on my i3's build plate.Standard Tesselated Geometry - 693.04 kB - 06/07/2017 at 09:38 |
