Assembly Completed
A project log for Object Following Control of a Robotic Camera Arm
Virtual Reality, Kalman Filter, and Inverse Dynamics Control
canberk-suat-gurelCanberk Suat Gurel 08/18/2017 at 11:100 Comments
The robot arm assembly is completed and the circuitry is tested.
The figure below shows the rest position of the robot arm. It can be seen that the Servo 4 has a slight offset of about 45 degrees. This issue can easily be fixed as shown in the 2nd figure.
