I'm currently testing out the laser printer at 600dpi, need to pump the numbers to 1200dpi and dual layer it. Most likely Ill increase the clearance after I complete the tests
A project log for DIY PCB KITs
I will be testing out different PCB kits,for quick prototyping before I send it off to OSH
