A bothering mistake and open-source for reasons
A project log for Tunnel-God-Detector
Detect and locate the magnitude and origin of tremors to support emergency respons teams
hornighornig 05/13/2017 at 15:120 Comments
Do you know this feeling when you find an itzy bitzy mistake in your creation that is so easy you should have found it?
After working for 24hrs on the prototype during the NASA Space Apps 2017 Challange, we missed a small type in this video (if you find it, you will forever see it :D)...
The good thing is, it is just a video editing thing and we guess it would happen to all of us after not sleeping enough and wrapping up the hackathon project.
If you don't believe us that this is the only mistake in this video, you can check our raw data. We put everything we recorded on our github repo for "Tunnel-Gott-Erkenner". The graph below shows everything we have from our sensor #3.
We support the Open-Source idea that we will provide everything we have. Firstly, it is fun to not work alone. And secondly, we know that someone out there has a crazy good idea what to do with the measured data or even provide the one idea that makes the full system better!
Have fun!
