3d Printed Scanning Electron Microscope
The goal is to build a DIY Scanning Electron Microscope (DIY SEM) with commonly available materials
A lot of people have the hobby to investigate the micro world with light based microscopes. With a scanning electron microscope (SEM) it is possible to investigate the nano world.
Unfortunately, SEM cost several thousand to some hundred thousand of dollars. However, a SEM consists actually only of few components:
a electron beam source
electronic or magnetic lenses
an electron detector and
a control unit
I reviewed the different components and I think it could be possible either to print or to buy the different components. I think that the housing could be printed with conductive and non- conductive material. For the lens, small super magnets could be suitable and for the control unit, an Arduino based platform could be used.
I am impressed about the impact of open source projects like 3d printer and microcontroller platforms. With this project, I hope to start something impressive too.
Simulation
A Simulation is available since the  Log 07/13/2017
Magnetic lens system Vacuum and electron beam
I have a magneticlens system since 11/06/2017
Housing
Since 12/28/2017 I have a improved housing
Electron detector
I have a schematic since 02/21/2018 for the detector amplifier
High voltage shield for Arduino
I populated the bare PCB about 03/16/2018
Overview and Introduction of SEM
1965 was the first Scanning Electron Microscope (SEM) commercially available (wiki). 2011 Ben build the first SEM at home. He used special equipment to build it. Now 2017 I start to build the first SEM with common available components. I would like to create imanges like these.
I will not explain the principles of a SEM because the explanation on the homepage of ammrf.org.au is great and I can't do it better.
Also the overview video from Ben is great for the introduction. But for a deep understanding I recommend the book Physical Principles of Electron Microscopy from author Ray F. Egerton.
My plan is to go ahead with the following steps:
  • Simulation
  • Vacuum and electron beam
  • Housing
  • Magnetic lens system
  • Electron detector
  • High voltage shield for Arduino
1. Build a simulation with a magnetic field simulation tool to determine the dimensions
I want use the tool FEMM 4.2. This tool is free and it is possible to create code based on Lua 4.0.
2. Build a suitable vacuum and an electron beam
... Read more »
  • Covered Photomultiplier
    Chris.deerleg02/01/2019 at 18:16 0 comments
    It is a long time ago, since my last log entry. The main reason for this, is that I moved from the US back to Germany. Therefor I was busy to find a new apartment and I had to wait for the container with all the stuff in it. Further I had to find a makerspace in my neighborhood with a laser cutter. I found one in Wiesbaden ( Makerspace).
    The image above shows the principle approach how I want to detect secondary electrons. My  previously design I wasn't able to detect anything. I had to much stray light and everything was a little bit shaky.
    Therefore I updated the design which is shown in the image above. In the right top corner is the space for the chamber with the sample in it. The light from the detector screen go straight to the first mirror and then to second mirror which guide the light to the photomultiplier.
    In the image above on the left side is the chamber shown and on the right side the chamber assembled in the detector arrangement. The electron beam come from the top of the chamber and hit the round area where the sample is. Secondary electrons are created symbolized by the purple cloud. The secondary electrons are attracted from the black spot which is conductive plastic. Hopefully, some electrons will hit the detector screen and create a reddish light. This red light follow the light path guided from the mirrors.
    In the image above is the view from the photomultiplier shown. In the right part is the detector screen through the mirrors visible.
    In the image above are the parts in the chamber shown. On the left side is the front view. The detector screen with the black spot is visible. In the middle is the side view. It can be seen that the detector screen is covered from the top and side. Just the bottom side is open to increase the likelihood that only secondary electrons for the sample are attached. On the right side is the sample holder shown. The with round are is a detector screen to visualize the electron beam and on the right side is a test patter.
  • Detector Photomultiplier
    Chris.deerleg07/30/2018 at 14:36 0 comments
    The image above show the new design which shall me enable to get a image out of my DIY SEM. The idea is that a voltage is applied between the target and a mesh in front of a phosphor screen. The secondary electrons are accelerated in the direction of the mesh. Some electrons hit the mesh and some other will hit the phosphor screen. Actually it is a screen made of a zinc sulfide. When the electron hit the screen photons are created. This photons will fly to the photomultiplier which convert the photons to electrons and multiplies these by 1.000.000.
    The image above show how it looks in the reality. The black long tube on the left is the photomultiplier. The withe piece behind the wire is the phosphor screen.
    I found my photomultiplier above (HAMAMATSU R1463-06) on ebay.
    The image above shows the photo multiplier pinning.
    Further I found I nice video from 1959 what explains how a photomultiplier works.
    The image show the supply voltage of the photomultiplier .The red PCB is a set-up convert which convert 12V in up to 1450V.
    Above on the image is shown the photomultipler with aperture. The piece of aluminum foil has a small hole in it. This is necessary to prevent that the photomultiplier saturate.
    The schematic above shows the components which are required to operate a photomultiper. The negative high voltage (-HV) is divided by 11 x 330kOhm resistors. The current through the divider is 344µA @ 1250V. According to a handbook of Hamamatsu  (https://www.hamamatsu.com/resources/pdf/etd/PMT_handbook_v3aE.pdf) shall be the signal current below 1/20th of the divider current.  At the out is a 220kOhm resistor to limit the maximum output voltage to 75V@344µA. At the end is a high pass filter with 470nF and a 470kOhm with a cut of frequency of 0.72Hz.
    One of my first test was just to point the photomultipler to the wall and illuminate it with my desk lamp. In this test I figured out that i need an aperture.
    The yellow signal is behind the high pass and the red one is before. In the signal can be seen that my desk lamp has small flickering.
    In the image above is my second test setup shown with a LED flashlight. The flash light was in a dim mode.
    The signal above shows in yellow the signal after the high pass and in red before. The signal show good that the LED flash light use a PWM signal to dim the light.
  • EMC Shielding
    Chris.deerleg06/08/2018 at 14:00 0 comments
    The image above show the current detector design which I have to reconsider because of shielding issues.
    EMC shielding
    https://learnemc.com/practical-em-shieldin
    The image above show how a shielding against a electrical field works. Please have a look on the page LearnEMC which explains quite well the background to shielding.
    In the image above I show how the shielding issue looks like. in the right corner, I connected the high voltage supple with the yellow and green cable. At the end of the cables I connected a screw drive with at voltage indicator. This voltage indicator is actually a glow lamp with a resistor. I placed the tip and the ground of  scope close close to cables.  In the right bottom, is the image of the scope shown. The image shows voltage peaks with approx. 12V. In the left corner I covers almost everything with aluminum foil. I left only a small hole to see the glow lamp. I was also important to cover the low voltage cables to the high voltage supply to get the best result. After all the effort in the left bottom corner is the result shown. The voltage peaks decreased to approx. 2V.
    Maybe the shielding issues are the reason that photo multiplier are so popular.
  • Detector plates
    Chris.deerleg05/11/2018 at 15:27 0 comments
    On the image above are the materials shown which I used to build the detector plates. With the laser cutter I made a support out of acrylic. I used sticky copper foil for the accrual detector plates and a piece of a soda can to make it stiffer. The laser pointer is a blue one and is great to cure UV glue.
    On the image above are shown different views of the detector . The foil with the hole in it, is for the backscattered electrons. The last magnet of the lens system is glued direct to the foil. The rectangle foil is for the secondary electrons. This piece is reenforced with the soda can and glued with two tiny spots of UV glue.
    Below the image show a view in the chamber with assembled detector plates. The black screw is made of nylon.
  • PC Software
    Chris.deerleg04/16/2018 at 20:59 0 comments
    The first communication test between the microcontroller and the PC was successful . The microcontroller transmit a chaining gray value and the GUI shows a image. The GUI was make with GNU Octave.  In the following I describe what the program do.It is quite ease to program it, if you know all the needed commands. So I hope the following helps somebody who is looking for: Octave GNU receive serial data, convert string to array, convert string to matrix, change size of a matrix, change size of array.
    h = serial("\\\\.\\COM6"); % Open the port
    srl_flush(h); % clear the buffer
    data = srl_read(h,200000); % read data from serial interface
    serialstring=[serialstring,data]; %add the new data to the buffer serialstring
    The code above is for Octave GNU. It opens the serial port,  read data from the serial port and add the data to a buffer.
    The image above visualize how the buffer content looks like. The buffer contains random data like "BEEF.." then transmit the micro controller a header like "480 Hello_World"  and the data of for example ADC chanel1 and ADC channel 2 in a 16 Bit format.
    header=[typecast(uint16(resolution.x),"Hallo_World")]; % create a header for the search
    matches=findstr(header,serialstring); % search the header in the buffer and return a array of matches
    serialstring=(serialstring(matches(1):end)); % remove the date befor the frist header
    The code part above creates the same header in Octave GNU as the micro controller transmits and search this header in the serial sting. The last line removes everything before the first header appear.
    The image above shows how the buffer look like after run the line of codes.
    serialstring=typecast(serialstring,"uint16"); %convert the buffer to uint16 because the microcontroller send uint16 too
    matches=findstr(typecast(header,"uint16"),serialstring); % search the header in the 16 Bit buffer
    The two line code convert the 8Bit serial sting to 16bit values and search again for the positions of the header because the previous positions were for a 8 bit buffer.
    % the image has as many rows as header exsist
    % the length of a row is the distance between tow heade
    imag=reshape(serialstring,matches(2)-matches(1),length(matches)); % create a imag
    The line of code convert the 1D sting in a 2D array.
    % the microcontroller send two channes
    imag_ch1=cast(imag(14:2:end,:),"uint16"); %remove the header and take each second value
    imshow( imrotate (imag_ch1,90)); % rotate the image by 90°
    The two line code above remove channel 2 and the header from the image. The last step is to rotate the image about 90° in show it.
  • PC Software
    Chris.deerleg04/06/2018 at 02:04 0 comments
    GNU Octave
    For the PC software I choose GNU Octave. A very powerful math tool kit with a option to include a graphic user interface. The download link for octave. Also very useful are the big variety of additional support packages on this page . I use the instrument-control package which contain the driver to user the serial interface. A useful descriptor for use the serial interface is this page https://www.edn.com/design/analog/4440674/Read-serial-data-directly-into-Octave.
    The above linked video series gave me a introduction to Octave GNU.
    Andreas Weber example code was very helpful to understand how a GUI in Octave is build.
    h.plot_title_label = uicontrol ("style", "text",
                                    "units", "normalized",
                                    "string", "plot title: (text)",
    "horizontalalignment",
    I struggled a little bit until I understood that with (h.xyz = uico(...)) ui elements are placed.
     h = guidata (obj);
      switch (gcbo)
    guidata (gcf, h)
    guidata store the handle of the ui elements and guidata and gcbo gives the handle back in the function.
    Another big challenge is to create a timer which calls periodically a function. I found a good approach on the following page https://savannah.gnu.org/bugs/?32316.  The approach is to use the event hook to call a function. I was able to call the function about every 100ms.
  • Electronic PCB
    Chris.deerleg03/16/2018 at 13:36 1 comment
    On the image above it the PCB shown which I made. I right lower corner of the PCB are the Femto ampere amplifier placed . The plain area surrounded with vias are the guard ring as I describe in the  last log entry. On the guard ring is the solder mask removed to get the bare resistance of the FR4 base material and don't "short" the FR4 resistance by the solder mask . The square pattern around the Femto ampere amplifiers are for a EMI Gaskets to improve the shielding for the case that I run in to EMC issues. In the square pattern above the Femto ampere ampere amplifiers are placed the secondary amplification stage with the MAX4450.
  • Detectorelectronic
    Chris.deerleg02/21/2018 at 03:11 0 comments
    The image above gives an overview how the electrons are collected and detected. The incoming electron beam triggers two types of electrons: the Back Scatter Electrons (BSE), which fly backwards along the beam and the Secondary Electrons (SE), which stay close to the target and don't move. Charged plates are located both above and alongside the target.  The image below shows how a picture looks with BSE compared to SE.
    http://www.ammrf.org.au
    I expect that the BSE and the SE current to be measured will be quite low. Therefore, I had to look for an amplifier with a very low leakage current of the inputs. I am glad that I now found femto ampere amplifiers for an affordable price. The LMP7721 from Texas Instruments and the ADA4530 from Analog devices.  Both companies have several application notes which explain how to use these amplifiers.
    Above is shown the whole schematic I created to measure the BSE and SE. In the next paragraphs I explain each part in more detail:
    A: This section shows the Femto ampere amplifier. The opamp is configured as a non-inverted amplifier. The reason is that with a configuration as a inverted amplifier it is hard to get a broad band width. For example a 1 GOhm resistor with a 1p capacitor in parallel would result in a cutoff frequency of 160Hz (f=1/(2*PI*1G*1p). Further The amplification is set to 2.48 (8.2k/3.3k=2.48) for stay in a comfortable area of the GBW (Gain Band Width) of the opamp.  The 10p capacitor set the low pass cutoff frequency to 1.94MHz (f=1/(2*PI*8.3k*10pF). The virtual ground (VirGnd=3.3V/2=1.65V) is set to the half supply voltage of the micro controller. The applied VirGnd voltage appear at the +input  of the opamp and make it possible to measure even negative current with just a single supply of the opamp. The 6k8 resistor in the input line limits the current in the case of activating the opamp internal ESD dioses. The 6k8 builds with the opamp internal capacity a low pass with a cutoff frequency of 2.12MHz ((f=1/(2*PI*6k8*11pF)) .
    B: This section shows the secondary amplifier. The Max4450 is a high speed opamp and has a band width of 175MHz. This make it possible to get amplification of 14,4 (Av=56k/3.9k) at 1MHz. The high bais current of 6.5µA requires to configure the opamp as a inverted amplifier, because in the configuration as non-inverted amplifier is it challenging to get a stable virtual ground. The low pass cutoff frequency of each opamp stage is set 2.4MHz ((f=1/(2*PI*56k*1.2pF)) . The 10µF input line creates a high pass with a cutoff frequency of  0.27Hz (f=1/(2*PI*{56k+3.9k}*10µF). This high pass blocks the DC voltage of each previous stage.
    The image above shows a bode plot over the whole amplifiers. The blue line is the signal at the +Input at the LMP7721  of section A and the green line is the output at the last MAX4450 amplifier of section B. The plot illustrate the whole schematic creates a amplification of 80dB. This mean that a 1 Femto ampere make a output of 10mV (U=I*R*Av=1fA*1G*10000).
    C: This section shows the guard amplifier. For measuring Femto ampere is a addition shielding required, which is in chapter 8.1.1 of datasheet of the LMP7721 described. The approach for this shielding is to surround the high impedance input of the femto ampere amplifier with a signal which has a equal potential but lower impedance. Analog Devices gives in the chapter Layout Guidelines of datasheet ADA4530 a good overview. The actual guard amplifier is a non-inverting amplifier connected to the -input of the Femto ampera amplifier.
    D: This section are just symbolizing the power supplies . The 5V power supply is for the amplifiers and the 3.3V for the virtual grounds.
    E: This section shows the generation of the virtual ground for the secondary amplifier. The resistors...
  • Vacuum Chamber
    Chris.deerleg12/28/2017 at 17:31 0 comments
    Thanks the Danbury Hackerspace I have now access to a laser cutter.
    I decided to make a new chamber because I need more space in the chamber that I can begin to build the electron detector. In the image above are the single parts of the chamber shown. The parts are made of 3mm acrylic sheet. The 5mm golden pogo pins are from Ebay and the black rubber rings are from sealing kit from Amazon.
    In the Image above are the assembled chamber shown.  The white round disk in the chamber is a Zinc Sulfide screen to visualize the electron beam.
    On the image above are the connections in side the chamber shown. The black tube is the connection to the vacuum pump. The clear tube below is the entrance for the electron beam. Left to the tubes are the pogo pins and a nut. These elements should connect the electron detector to the outside. On right side are three pegs visible. With these pegs I want to measure the vacuum because I had a lot of trouble with the vacuum in the past.
    On the image above is electron beam in the chamber made of acrylic plastic shown.
  • STM32 Hello World
    Chris.deerleg12/15/2017 at 21:10 0 comments
    I started with the microcontroller. I programmed already several, but it is still the same. Its a pain in the neck until the tool chain is running and the "Hello World" led is blinking. I decided to use a STM32F103C8 because of the high clock frequency 72MHz and the 32Bit architecture. On the image above is my setup shown. Between the PC and the hub is USB isolatora from Ebay. Just for the case of something goes very wrong to protect my PC. The hub has the nice buttons to turn off each USB connector. The blue USB programmer is a  ST-Link V2 from Ebay too.
    One remarkable thing is that you need a additional rest cable which wasn't delivered with the programmer.
    As IDE I use the pre-configurated eclipse version from AC6 which is available for download at toolchain .
    The video above shows how to use the USB of the STM32.
View all 25 project logs
Butch O'Dowd wrote 08/13/2020 at 20:11 point
Really cool project. There is currently an auction going on where a old EM service company is liquidating TONS of EMS and parts. Service manuals full of secrets as well. Check it out here: https://www.slapsale.com/ss/#!/auctions?ilt=1&sid=40479  I used to be a Service Engineer, and I can tell you you can learn a lot working on the old scopes!
wolken wrote 05/09/2020 at 05:38 point
Please finish this project is so coooool !!!!
Adi wrote 12/09/2019 at 12:22 point
Really like the project, I was sure someone tried building one at home, give cost of buying one is astronomical. Wondering if you are still continuing with your project, and if you got any images?
Chris.deerleg wrote 01/22/2020 at 20:48 point
If I have one I will show it. Unfortunately it's incredible difficult. Now I know better why other SEM have so many special parts. But I don't give up :-)
Mohammed wrote 12/16/2018 at 21:20 point
Great project, great challenge. Can you tell us how this project progressed?, did you start getting images already?!
mtripoli wrote 08/28/2018 at 17:18 point
Hi,
I looked over what has been posted here, and though I commend you on your interest, and testing of concepts, I think you need to re-evaluate a couple of things. Not to put too fine a point on it; I used to design scanning electron microscope "sub-systems"; the SE and BSE detectors (BSE with a PMT), lens amplifiers, power supplies, control systems, image acquisition, etc.
First thing; a very crucial aspect of what you're doing appears to be missing; shielding around the "column". Whenever there is an "electron beam" present, there are also X-RAYS. Do not underestimate how much X-RAY is coming from even a small beam. You mention shielding for EMC, but nothing more. If you study a commercial SEM, you'll see that there is quite a bit of "metal" between you and the beam. If it were me, I'd get one (or a few) of the radiation badges x-ray tech's wear to see how much exposure you've had.
Fields and vibrations are the enemy of the SEM. An SEM column typically uses a "floating table", literally held up with air. These systems cost a small fortune, so probably not going to help. One solution that goes back to the first atomic force microscopes (AFM); get a large block, such as stone (granite) suspended by bungy cords from the ceiling. This provides a tremendous amount of decoupling from its surroundings; if they can image atoms this way, it'll work for a DIY setup.
All of your electronics are going to have to be as "low-noise" as you can possibly make them. Power supplies, detector amplifiers, etc. are critically important.
If you ever expect to get any kind of "image", beam quality is paramount. From the condenser lens on down (scan coils, objective lens, stigmation) all need to be considered such that you get as "round" a "spot" as possible.
The "detector" based on a PMT is known as an Everhart-Thornley detector, and depending on how the "front ring" is biased, one can get either secondary (SE) or back-scatter electrons (BSE). Remember;  BSE have *almost* as much energy as the beam, and good for atomic number contrast images, but will not give you topographical information. Secondary electrons give topographical information, but are much lower energy (depends on the atomic number of the sample), leading to the "contributing volume" of the sample. Because SE are relatively low energy, a low-noise, high gain amplifier is mandatory. BTW; PMT's should *never* be exposed to bright light; even "average room light". If they are, they can saturate such that it can take many hours, even days, for the PMT to recover. Hammamatu has white papers that talk about the proper use of PMT's.
Anything exposed to the beam can "charge up", especially plastic. These minute charges WILL deflect the beam, in ways that you do not want. Everything has to be firmly bonded to "ground". This is true of the sample as well; it is common to use either colloidal graphite or silver to "glue down" the sample to the sample stub. The stub must be "grounded". If not, (this is true for anything exposed to the beam); it will charge up and the image will "wash out". This is because the non-grounded objects will collect electrons and "charge". These charges, again, will deflect the beam.
I realize you're doing experiments, and may not be expecting to get a "great" image. But before proceeding, you might replace the glass parts with metal, get the device mechanically isolated, and lot's of shielding against fields.
Good luck!
Mike Tripoli
SCARY Design
Saidurga Karthikeyan wrote 11/15/2017 at 06:19 point
Even I am working on to build a Scanning Electron Microscope from scratch. Hope this serves as a good source for me.
Chris.deerleg wrote 07/27/2017 at 19:01 point
Thanks for you explanation. I will have you thoughts in mind and maybe it reconsider in a later stage once the first real particles fly.
ballsystemlord wrote 07/03/2017 at 20:32 point
I joined hackaday just to follow awesome projects like these!
Perhaps you are currently having troubles with vibrations and that is why your formulas are off?
Chris.deerleg wrote 07/04/2017 at 07:33 point
Thanks for joining. What do you mean exactly with vibrations?
ballsystemlord wrote 07/22/2017 at 02:10 point
(Sorry for the late reply, I can't get online often.)
Not that I'm an expert in the field, but if you are firing electrons (atomic particles), and then a vibration strikes the machine, all that that vibration has to do is to knock the machine at an atomic level to the point where is sends the electron in an unanticipated trajectory thus causing you to think that there is something wrong with your calculations.
Mind, I can't prove this to be the case. It could be that the magnetic fields compensate for the vibrations (that is to say, when the device moves as a result of a vibration the magnetic field remains in the same place and just changes in intensity slightly, due to the proximity to the magnet).
