PC Software
A project log for 3d Printed Scanning Electron Microscope
The goal is to build a DIY Scanning Electron Microscope (DIY SEM) with commonly available materials
chrisdeerlegChris.deerleg 04/06/2018 at 02:040 Comments
GNU Octave
For the PC software I choose GNU Octave. A very powerful math tool kit with a option to include a graphic user interface. The download link for octave. Also very useful are the big variety of additional support packages on this page . I use the instrument-control package which contain the driver to user the serial interface. A useful descriptor for use the serial interface is this page https://www.edn.com/design/analog/4440674/Read-serial-data-directly-into-Octave.
The above linked video series gave me a introduction to Octave GNU.
Andreas Weber example code was very helpful to understand how a GUI in Octave is build.
h.plot_title_label = uicontrol ("style", "text",
                                "units", "normalized",
                                "string", "plot title: (text)",
"horizontalalignment",
I struggled a little bit until I understood that with (h.xyz = uico(...)) ui elements are placed.
 h = guidata (obj);
  switch (gcbo)
guidata (gcf, h)
guidata store the handle of the ui elements and guidata and gcbo gives the handle back in the function.
Another big challenge is to create a timer which calls periodically a function. I found a good approach on the following page https://savannah.gnu.org/bugs/?32316.  The approach is to use the event hook to call a function. I was able to call the function about every 100ms.
