Vacuum Chamber
A project log for 3d Printed Scanning Electron Microscope
The goal is to build a DIY Scanning Electron Microscope (DIY SEM) with commonly available materials
chrisdeerlegChris.deerleg 10/20/2017 at 16:170 Comments
Now I know one reason more why I had trouble to see a electron beam. The vacuum was too bad.
I figured out that electron beam disappear if I place a wire with 0.3mm between the rubber plug and the gals wall.
Further I figured out that by changing the spark gap from the anode side to the cathode side I could remove the aluminum strip from the bottom of the glass. Also I changed the screen material from glowing in the dark powder to pure zinc sulfide.
