Hackaday.io Hackaday.io
Sign up Log in
Open Source Micro Cassette Player
It wont look like the elbow elbow cassette player (different)
ricardo-ferroRicardo Ferro
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.5k views
7 comments
2.8k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 12
    • View all
  • Instructions 0
  • Discussion 7
  • The 2017 Hackaday Prize
View Gallery
3.5k
7
2.8k
26
Team (2)
  • ricardo-ferroRicardo Ferro
  • jackcyberjackcyber
Join this project's team
  • BOM
hardware
ongoing project
cassette 2017HackadayPrize
This project is submitted for
  • Internet of Useful Things
This project was created on 05/08/2017 and last updated 7 years ago.
Description
I saw the concept art on a website called the Verge, and decided that ill build by own, and open source it . <a href="https://www.vcalc.com/wiki/vCalc/Belt+Pulley+RPMs" target="_blank">https://www.vcalc.com/wiki/vCalc/Belt+Pulley+RPMs</a> If anyone wants to join the project, send a request or help via comments below or chatlogs.
Project Logs
Collapse
  • captains log 13
    Ricardo Ferro • 10/20/2017 at 04:03 • 0 comments
    Im not dead, im assembling it and testing it with the ocilloscope, to make eveything alot easier and cheaper, ill just use the power source as a 5V which any home charger can handle.
  • log11
    Ricardo Ferro • 07/16/2017 at 04:25 • 0 comments
  • Captains Log #8 or 10
    Ricardo Ferro • 06/25/2017 at 14:55 • 0 comments
    designing the tape head pcb
  • Captains Log #9
    Ricardo Ferro • 06/18/2017 at 14:29 • 0 comments
    got the motor in the mail !
  • Captains Log #8
    Ricardo Ferro • 06/04/2017 at 17:49 • 0 comments
    Hey everyone, I took a different approach to the cassette tape speed and I found an alternative motor for driving cassette tape. I did simulations to play the cassette tape and the rpm varies between 20-50 rpm. The motor is small which is good becauseit keeps the small form factor.
  • Captains Log #7
    Ricardo Ferro • 06/02/2017 at 13:46 • 0 comments
    Small change on Distributor to Wuhan P&S
  • Captains Log #6
    Ricardo Ferro • 06/01/2017 at 16:57 • 0 comments
    Ok i'm just ordering parts for measuring RPM from EMF. Based off the overall project I think only an arduino pro mini or teensy might be used. Thats good because the cost to build this thing will dramatically decrease.
  • Captains Log #5
    Ricardo Ferro • 05/31/2017 at 17:05 • 0 comments
    I just received 5PC pkg today. I'm just waiting on the giant book of resistors/caps to come in the mail next week.
  • Captains Log #4 RPM
    Ricardo Ferro • 05/11/2017 at 06:35 • 0 comments
    The tape has to move at a constant 4.76cm/s rate. Based off the protoype design it didn't include the tachometer to measure the linear speed.
    Im going to list 3 ways it may play correctly
    1. No tachometer, uses a microcomputer for reading the cassette tape and use software to stabilize the changing play speed
    2. Add a tachometer to read the 4,76cm/rate but the design becomes bulkier with extra parts.
    3. We discover a new way to play a cassette tape at the right speed somehow.
  • Captains Log #3
    Ricardo Ferro • 05/10/2017 at 06:09 • 0 comments
    Thanks to @Morning.Star for recommending a pre-amp for the Casette Tape Head. A Youtube video a google search later
    http://piperidis.smartdev.gr/MyWebPage/Contructions/Amplifiers/tapeplayer/tapeplayerEN.htm
View all 12 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Rupert Hirst wrote 04/16/2021 at 23:07 • point
Interesting concept,
Quick question, how are you going to keep wow and flutter in check with only one spindle.
Nathan Stanley wrote 06/02/2017 at 04:41 • point
Very cool nascent project. Looking forward to seeing how things progress!
Ricardo Ferro wrote 06/27/2017 at 23:05 • point
thank you! ill update the progress in a few days
K.C. Lee wrote 05/11/2017 at 18:08 • point
@Morning.Star Microchip TC652 uses FanSense(tm) to sense commutation of a DC brushless fan.  They basically AC couple the current signal from a sensing resistor.
Martin wrote 05/11/2017 at 08:58 • point
The speed is (was) normally stabilized without a tachometer, except in high class tape decks. Often analog motor control chips were used which evaluate back EMF of the motor and/or implement some kind of "negative resistance" to compensate for the rotor resistance. Without this resistance the moor speed would be perfectly proportional to the applied voltage, independent of mechanical load.
Sometimes such a control circuit was included into the motor casing.
Another possibility would be a brushless motor, where you get inherently a frequency proportional to it's speed. This can also done sensorless by evaluating back EMF of the winding which is not driven at the moment.
Ricardo Ferro wrote 05/11/2017 at 16:02 • point
Thanks for the insite I will have to do research into back EMF, and the different possibilities including some that you suggested/.
https://www.precisionmicrodrives.com/application-notes/ab-021-measuring-rpm-from-back-emf
Morning.Star wrote 05/11/2017 at 16:52 • point
We meet again lol
hackaday.io/project/20876-origaime-cardware-bis/log/59055-skunkworks
right at the bottom...
Except my motor has a commutator. I was thinking of sampling the feed and counting the EMF spikes for metrics as a free replacement for encoder wheels etc, but I'd never heard of it being done. Damn, but at least I know it works. :-)
This display is being design and built for a local dance company as a set piece, exploring the concept of travel and transit.
Project Owner Contributor
Split Flap Display
mlomlo
The 2016 Hackaday Prize
A set of designs to facilitate teaching and intuitive understanding of the relationship between electricity and magnetism
Electromagnetic Teaching Aid
adam-smallcombAdam Smallcomb
The desktop microfactory of toilet tissue from recycled paper
Toilet Paper Microfactory
daniel-nikolajsenDaniel Nikolajsen
Turn any room into a home theater.
Projector Lift for Home Theaters
sam-bakerSam Baker
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Open Source Micro Cassette Player", please tell us the reason.
Send message
Remove Member
