Extending DVP: Running an OV2640 on the ESP32-S3 Over an FFC Cable
A project log for Hexastorm: Rotating Prism Laser Scanner
High-Speed Sub-50 µm Laser Direct Imaging (LDI) & Additive Manufacturing
hexastormHexastorm • 07/29/2026 at 08:31•0 Comments
Hardware Win: Extending DVP & Ditching the Pi Stack
If you've ever worked with stock camera modules like the OV2640, you know the default ribbon cables are infuriatingly short. For my custom board setup, the stock cable was nowhere near long enough to reach under the laser head. I was banging my head against the wall, assuming I’d have to give up on DVP entirely and shell out for a significantly more expensive USB or SPI camera setup.
Instead, I decided to test signal limits by extending the OV2640 using a 90 mm FFC cable coupled with a 24-pin Adafruit FFC extender. Because Digital Video Port (DVP) uses high-speed parallel lines, extending it isn't plug-and-play—trace impedance matching and signal integrity become make-or-break fast. It didn't work right out of the box, but once the impedance was dialed in, it delivered a crystal-clear image. This trick allowed us to retire our old, bulky camera stack (a Raspberry Pi tethered to an Arducam) in favor of a lean, direct ESP32-S3 connection directly on our custom PCB.
Clean image capture via extended DVP interface
Clean image captured over the extended DVP connection.
Hardware camera stack setup transition
Replacing the old Pi + Arducam stack with a direct ESP32-S3 interface.
Open Source Realities, AI Velocity, and Recent Wins
Overall progress on the project has been flying recently. Going open source gave us fantastic marketing traction and project visibility, though outside code contributions have been sparse—the system is simply too technical and time-consuming for most casual builders to dive into. Plus, let's be real: most people just don't enjoy writing code from scratch.
However, modern AI models have completely shifted the math on solo hardware/software development. Feeding deep technical specs, hardware constraints, and even half-baked architectural ideas into LLMs has turbocharged our feature velocity. Having detailed project documentation public online pays unexpected dividends here—AI models can ingest the full context instantly (and might even train on it for future iterations).
Thanks to this accelerated workflow, we've been landing major wins almost daily:
There's certainly no shortage of things left to improve, but turning complex custom hardware into a streamlined, functional machine is getting faster every single day.
