New build
A project log for prism laser scanner
bringing additive manufacturing to the next level
HexastormHexastorm 10/27/2021 at 16:392 Comments
Feel free to fork https://github.com/hstarmans/hexastorm_design
I will post a making off video soon.
Gravis wrote 10/27/2021 at 22:03 point
I think figuring out how to precisely affix the polygon in an entirely repeatable fashion should be your next step.  I can't help but think the polygon should be cut to accommodate a fastener of some sort.  When you have a dead center fastener then you can built it as starting point for making your own polygon motor.  Eventually, it may be possible to put all components on a single PCB which would reduce things like alignment issues as well as the overall size.
Hexastorm wrote 10/31/2021 at 10:20 point
I made a blog on the current motor pcb.  I have a technique for fixing the prism now which is quite okay. It takes minutes, making the electronic boards and wiring is the most time consuming step. This can take hours if you do it by hand.
I think most import for developers is that the technology is robust and the software is refactored enough so new components can be added.  The last days I tried to improve deployment using poetry, https://python-poetry.org/ , and the like.
