The boards sponsored by PCBWay are shown below. Progress in the last days has been good.
Following things are working: prism motor (spins), laserdiode (can turn on & pogo pin system works), TMC2209 communications work, ESP32 and ICEUP5K (FPGA) work.
Progress has been as follows:
- 9 december: received boards
- 14 december boards populated & compute board working
numbers of some parts where wrong, which required extra shipment from mouser
- 19 december extension board populated (after receipt parts)
I encountered a bug.
- 30 december bug has been resolved
Two issues: - schema error (5V connected to 3.3V, this has been mitigated with soldering tricks)
- stepper motors communicate via UART1 which can create issues with UART0 (micropython repl)
this is a bug upstream but can be mitigated by a trick in the boot.py script.
- 2 january Destroyed laptop (applied 12V over USB input)
- 6 january Mounted motor, encountered issues moved to different board
- 7,8 january Changed code, ESP32 communicates with FPGA, spinning of prism work
- 9 january Laser works (forward diode voltage of 2.5V)
- 13 january Laser can be calibrated while on (pogo sytem works good)
Laser diode prism test --> pass
- 14 january Stability test / Mounting on machine
laser reaches stability criterion
mirror position without cylinder lens does work
mirror position for cylinder does not work
(cylinder lens might work, mirror position not optimal, needs testing)
- 18 january x and y motor work, homing switches work
spi unreliable (fails every 100_000 writes)
- 21 january spi issue fixed; (bad soldered bord + incorrect setting)
- 22 January test exposure works (resoldered x-dir pin)
- 2 february micropython code optimized, check added to ensure micropython
can feed data fast enough to the laserhead
- 13 february all buttons are functional, only print remains now
Current challenges remaining
- fine tuning optics & test exposure with microdot webserver
Hexastorm
