Lessons Learned
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 03/27/2026 at 13:550 Comments
Sometimes in hardware design, you have to take a step back to move forward! I was ready to finalize my effors with a video using facet correction to make a PCB, but I've hit a wall: my stepper drivers are dead. After doing some digging and testing multiple setups, I found the culprit. The drivers were only surviving on a wing, a prayer, and a few hacks.To do this right, I'm retiring the V1 board and starting fresh.
Here is the roadmap for the new design:
Realistically, this means physical video updates are on pause, though I’ll try to share some 3D renders of the new setup soon. But honestly? I'm thrilled. The facet correction concept is officially proven in the camera setup, so I know this redesign will be entirely worth the effort.
