Finished routing board
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 04/18/2019 at 16:540 Comments
I finished the routing of the new Firestarter Cape;
The cape has the following improvements;
The current board can be used for 3D printing.  Although, you might want to add a tilt motor, recoat motor and temperature control for your resin.  Some machines use force-feedback,  which is patented.
The boards still have to go through some final checks, probably you can't run 30A through the board.
Code can be found here ; firestarter
