PCB motor
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 11/04/2021 at 15:380 Comments
Gravis asked my opinion on using a PCB motor with a prism.
In short, it seems possible to spin a prism with this motor but the prism most likely needs to be smaller.
This motor has a diameter of 15 mm,  my prism a diameter of 30 mm. Of course, prism dimension can be changed.
The prism can be placed in a low drag gas like helium. So far Carl seems to focus on torque and speed, an important quality for me is actually planarity. How planar is the rotation? At 5 minute 43, he shows the side ways wobble of his amazing device. This kind of wobble is undesirable and would require a cylinder pair to filter it out. This increases price which kills the low cost advantage of the motor.
Small prisms are desirable for high accuracy applications.
I would try to create a digital twin, this would greatly improve understanding.
Options I see
             - Magpy Lib: should be easy for a quick experiment
            - Pyleecan: geared to motors but does not have example of this exotic geometry
              -      Elmer Fem , can be linked with open foam, probably too advanced and not suited
                                          for exploring the problem
  would make the board in kicad and not altium. An interesting script i found is (given above see hackster link). It think @carlbugeja did amazing work. For the time being, I will focus on other challenges; i.e. making the tech reliable.
