New lane alignment
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 11/16/2021 at 17:452 Comments
New alignment between lanes is shown below;
  I have assumed backlash is zero
  The width of a scanline is 5.54 mm, still I use 5.4 mm in reality, to achieve stitching.
Results look pretty good. Should be more than sufficient for PCBs.
Gravis wrote 11/16/2021 at 19:07 point
Please add a picture of a closeup of the 70um part.  JPEG compression makes it look like a solid block.
Hexastorm wrote 11/17/2021 at 11:14 point
You are right!! Should have made a picture with a close up... maybe once I have a PCB image
