Prism motor new magnets
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 05/18/2022 at 13:350 Comments
 - Magnets increased from N52 8x2 to N52 10x5 and the pull force went from 1.1 kg to 3.6 kg.
 - Stronger magnets made me realize I had a mistake in my algo, improving the algo also increased torque.
 - The motor died due to ESD at my workplace. I am still waiting for material so I can properly ground myself
    I had to replace the FPGA and the motor chip
  - motor can reliable self start
  - motor requires lower current and voltage (5 volt suffices), heat has become less of an issue.
