sws
05/28/2017 at 02:53 • 0 commentsl -
Captains Log #9 : Final Testing
05/28/2017 at 01:06 • 0 commentsThe oven worked perfectly!
Ill add the components and instructions on the description section.
Captains Log #8
05/21/2017 at 04:02 • 0 commentsJust received the boom mat, handled with gloves because it has fiberglass, waiting on the gold tape.
Captains Log #7
05/19/2017 at 04:58 • 0 commentsJust recieved the Toast-R-Reflow Control Backpack 2 v0.1.1 by Geppetto Electronics here, It looks promising. Also we have a sexy Black n Decker TO1313 oven in the background
Captains Log #6 The Toaster
05/16/2017 at 05:33 • 0 commentsI chose the Black Decker TO1313SBD because of it Even Toast Technology. as well as a pcb oven tray.
Captains Log #5 Insulation
05/14/2017 at 17:40 • 0 commentsGetting some insulation supplies
Captains Log #4 Shopping For Toaster Oven
05/14/2017 at 16:40 • 0 comments -
Captains Log #3
05/14/2017 at 03:39 • 0 commentsIm going for the Toast-R-Reflow controller + Power kit.
Captains Log #2
05/13/2017 at 04:38 • 0 commentsAfter a hard look at the screen i came up with these choices
The ratings dont look so good for T962, looks like modifications will be needed.
based of whizoo
- Infrared is absorbed at different rates, so expect darker components to heat up much quicker than lighter ones.
- The oven does not conform to the J-STD-020 reflow standard. Specifically, it fails to meet requirement 3.2.2: "It is required that this equipment use IR to heat only the air and not directly impinge upon the SMD Packages/ devices under test."
- All the heat comes from the top. Imagine trying to reflow a microcontroller - the black microcontroller will absorb a lot of the infrared heat while shading the PCB underneath it. This creates a huge temperature differential!
DIY reflow component kit called ControlLeo2, looks like it uses a black n decker oven, doesn't look too bad at all
Captains Log #1 Google Ad Tracking helping
05/13/2017 at 03:43 • 0 commentsThankfully Google reminded me via ads on youtube to get a Reflow Oven. So far I see some Sky High Prices. The sub 200$ seems decent, ill have to check the reviews.
