Gear now uses 1.2mm x 20mm nails. Just flat head is cut off with side cutters. With correct size of hole, pins are easy to push in into correct depth. Little screw locking is applied into hole beforehand. Ordered some HAL sensors from TI. When arrives, try to experiment position sensing with those.
