Does it make sense to localize BASIC keywords?
A project log for Terminal-BASIC
Language interpreter for uC-based systems
andrey-skvortsovAndrey Skvortsov 04/10/2019 at 22:033 Comments
As I wrote earlier, TB 2.0 (rc1 for now) has the ability to use different keyword sets in any single-byte encoding. If you are a TB user and if you consider useful some alternative keyword set in your native language, it can be included in future release of Terminal-BASIC. Now there was created a Russian keyword set, based on such, used in BASIC-6 system for БЭСМ-6 mainframe.
English
Русский
French
AND
И
DATA
ДАННЫЕ
DEF
ОПР
DIM
РАЗМЕР
END
КОНЕЦ
FIN
FN
ФУНК
FOR
ДЛЯ
POUR
GOSUB
ВХОД
GOTO
НА
IF
ЕСЛИ
SI
INPUT
ВВОД
LIRE
LEFT$ ЛЕВ$
LEN ДЛИНА
LET
ПУСТЬ
LIST
ЛИСТАТЬ
LISTER
MAT
МАТ
MID$ СРЕД$
NEXT
ЦИКЛ
NOT
НЕ
ON
ПРИ
OR
ИЛИ
PRINT
ВЫВОД
AFFICHER
READ
ВЗЯТЬ
REM
КОМ
RESTORE
СНОВА
RETURN
ВОЗВРАТ
RETOUR
RIGHT$ ПРАВ$
RUN
ПУСК
STEP
ШАГ
STOP
СТОП
STR$ СТР$
THEN
ТО
ALORS
TO
ДО
JUSQUA
Alan Green wrote 08/06/2019 at 21:45 point
To answer the question in your title: Yes!
BASIC is a great language for beginners but having to work in a second (or third, or fourth) language while one learns is counter-productive. This is great :)
Andrey Skvortsov wrote 08/06/2019 at 22:31 point
Yes, I found native keywords set useful when I started to teach my 5 years old daughter some BASIC programming.  It's hard to explain her both English and BASIC languages  at the same time.
Andrey Skvortsov wrote 08/06/2019 at 15:09 point
I will try to add French keywords, based on LSE (https://fr.wikipedia.org/wiki/LSE_(langage)) language
