• 1
    Step 1
    Model Printing
    Download address of model: http://pan.baidu.com/s/1gfP3GYZ (Baidu Netdisk)
    Printer used: OverLord pro 3D printer
    Model printing. Cura setting parameters are shown below:
  • 2
    Step 2
    Fixing Model
    Look around and find a base that could make the model higher, and bind 3D print Groot and the base together with double-sided adhesive.
  • 3
    Step 3
    Adjusting Color
    1. Pour a small amount of pigment thinner in a small vessel as brush washing liquid and diluent in advance;
    2. Firstly, we try to use cooked brown, black and emerald green to adjust the basic color for Groot body;
    3. You can refer to the ratio in the picture for the adjusting proportion of coat. If the actual adjusted coat is dark, you can add some white pigment;
    4. You can put two or three drops of thinner when adjusting pigments, which contributes to integration of pigments, but don’t put too much.
    5. Evenly mix the pigments directly with the brush
