ERASynth vs Rigol DSG3030 vs Agilent E8257D
A project log for ERASynth
Open-Source, Arduino-Compatible RF Signal Generator with Wi-Fi Connectivity
edensrockedensrock 05/31/2017 at 12:460 Comments
If we were to name one area where ERASynth truly excels at, it would be the pedestal phase noise. (phase noise at offsets from 1kHz to 100kHz)
A signal generator’s pedestal phase noise has different impacts on the system depending on the application. For example, when used as a local oscillator in a receiver application, pedestal phase noise degrades the receiver sensitivity. When used as a clock source in a data converter, pedestal phase noise (together with close-in phase noise) determines the jitter, which ultimately effects the converters dynamic performance.
We carried out a test to compare ERASynth to a couple of bench-top signal generators available in our lab. Here is the result:
The graph above is obtained using this setup.
