close-circle
New PCB clearence
A project log for Debug Board
Simple, tiny USB to rs232 converter, also with a galvanic isolation
fattore.saimon 05/29/2017 at 12:450 Comments
Unfortunately we discovered a problem with the PCB layout.
The clearance is not meeting the requirente for the high voltage insulation.
For this reason we made a new PCB layout with 4mm clarence, enough for isolate up to 1kV
