The S4 (Small Satellites for Secondary Students) student satellite system is an opportunity to do science experiments as rocket and balloon science payloads targeted to middle and high school students - but also useful to a much wider range of curious learners.   It is based on over 20 years of the international ARLISS program of university and high school student payloads that invented CanSats, CubeSats and autonomous recovery satellite robots.   It uses the PocketQube format for small satellites that is the inevitable successor to CubeSats and CanSats via Moore’s Law.
The S4 vision is to imagine a progression of science experiments rooted in missions on the ground or on small rockets such as TARC, progressing to missions to a few thousand meters on high power hobby rockets (like ARLISS), extending to sounding rocket or high altitude balloon missions to tens of kilometers high in stratosphere and exosphere (like ARLISS Extreme) and eventually to PocketQube missions deployed into Low Earth Orbit.   Each step challenges student imagination and abilities with an incremental increase in  scope, risk and cost - based on a common platform.
The wide range of sensors and extensibility of the S4 system allow for missions in the atmosphere or the ground (and eventually space!) that are largely only limited by the learner’s imagination and are tantalizing close to the capabilities of Star Trek’s tricorder.
Each 2019 S4 satellite payload is inspired by the new standard PocketQube picosatellite format (in the 1p format, 5 cm on a side, in the 1.5p format - 5 x 5 x 7.5 cm, ~300 gm) - invented by Professor Bob Twiggs, inventor of CanSats and co-inventor of CubeSats.   Each S4 satellite contains a portfolio of sensors and is programmed as an advanced Internet of Things Cortex ARM computer.   Configurations with minimal sensors can be as inexpensive as $50, and full-up configurations with multiple sensors and telemetry can reach over $200.  Core data collection loops can exceed 20 Hz, with multi sensor collection loops delivering 5-10 Hz.
S4 collects data locally on the satellite in non-volatile flash memory.   Higher end S4 payloads can add real time radio telemetry using modern spread spectrum long range radio communications to communicate to ground stations and download real-time telemetry from the mission and track payloads via GPS.
The system is extensible and new sensors can be added to each S4 satellite for new and different missions.   Users can make use of the default sensors and mission programming or add new sensors and programming.
S4 satellites are designed to be flown on rockets as small as TARC rockets or drones that fly a standard hen’s egg size payload on F and G motors to 1000’ up to high power sounding rockets or balloons that reach the top of the stratosphere.  S4 satellites can be configured for either captive flights or to be deployed at apogee on a recovery device (such as a parachute) for independent descent.   The PocketQube format allows for an incremental transition to an ultimate space capable packaging suitable for LEO deployment.
The S4 program anticipates rapid technology changes in platforms and sensors and has tried to standardize on common standards for programming language, packaging, communications and sensor interfaces.
Missions
Science is about asking and answering questions about the world we live in.   S4 is such a tool to ask questions about the earth and the space the around it using rockets and high altitude balloons as interesting platforms to observe.   They provide opportunities to investigate second hand (by our robots and their sensors) deep questions about the earth and its environment.
S4 leverages three amazing recent innovations in citizen science:
S4 is a modular set of tools allowing a range of science missions in different  S4 configurations - ranging from a simple one like S4Egg at low altitude, and a more complex one like S4Qube to the stratosphere.  S4Egg is suited more for younger learners and simpler missions (say middle school)  while S4Qube for more sophisticated learners and more complex missions (say advanced high school).     These are illustrative not prescriptive.
Since S4 is in the standard PocketQube format we can imagine, with modest modifications, extending these missions to LEO.
S4Egg has a relatively simple portfolio of atmosphere sensors with data sampled at 10 Hz:
It is configured as a 3D printed PLA enclosure in the shape of a hen’s egg replacing the payload of a TARC rocket.   It weighs ~30 grams and can be thought of as a sensor measuring the basic chemical content of the Earth’s atmosphere column.
S4Qube has a rich portfolio of sensors with most data sampled at 10 Hz:
eCO2,
It is configured as a 3D printed PLA 50mm 1p cube for either captive flight or independent deployment for parachute recovery.  It weights about ~150-200 grams. Spread spectrum wireless telemetry allows for independent tracked recovery.   Additional sensors can be configured on standard extension busses (I2C, serial, 1-Wire, DIO).   Open source data collection and telemetry software is Arduino/C++ based.
S4Qube has an experimental multispectral imaging sensor cluster combining a low resolution false color visible light camera, coaxial with a thermal imaging camera  and an optional spectrometer designed for ground examination.   It is hopes that this imaging sensor cluster can be used for false color vegetation and crop analysis.
S4Egg Missions
S4Egg missions are based on questions suitable for middle school science.
Question
Sensor(s)
Study Guide
How do we determine altitude from pressure in the atmosphere?  What IS the atmosphere?
Barometer
Temperature
Atmosphere
What is humidity?  How does water content in the atmosphere change with altitude?   Time of year?  Location?
Barometer
Humidity
Temperature
Atmosphere
How does CO2 in atmosphere change with altitude?   Time of year?  Location?   Vegetation?
Barometer
Humidity
Temperature
Atmosphere
How does pollution from TVOCs change with altitude?  Location?  Adjacent sources of pollution?   What ARE TVOCs?  Time of year?
Barometer
TVOC
Pollution
Organic compounds
How are any of the above related to temperature?  To each other?
Temperature
Weather
How do answers to any of the questions change in different locations or at different times or seasons.
Weather
How fast did the rocket go?
Barometer
Physics
Atmosphere
How high did the rocket go?
Barometer
Physics
Atmosphere
S4Qube Missions
A rocket based mission to 30k’ can take advantage of the rich portfolio of S4Qube’s sensors to ask many more questions.   Such a flight will be supersonic and will pass from the troposphere into the lower edge of the stratosphere, and likely into the jet stream (depending on jet stream and location).    On such a flight several S4Qubes could be flown and multiple questions could be flown from multiple sensors on different subjects.
Question
Sensor
Study Guide
How fast and high?   Do GPS and barometer agree?
GPS
Barometer
Physics
Atmosphere
What was the path of the rocket flight?
GPS
Physics
Mapping/visualization
What did the airframe experience?   Stress?   Temperature?   Acceleration?
IMU
Temperature
GPS
Aerodynamics
Strength of materials
Physics of rocket flight
What were the physics of the rocket’s flight.   How much drag was on the rocket.   How could you measure it?  Did it change with altitude?   How?
IMU
Barometer
Temperature
Aerodynamics
Physics
Atmosphere
How much energy did the motor put out?
IMU
GPS
Design of rocket motors.
Chemistry
Physics of rocket motors
What did the atmosphere look like during the rocket’s flight?   What did it consist of?   How did it change?   Why?
Barometer
Temperature
Humidity
Particulate matter
TVOC
CO
eCO2
Radiation
Composition of the atmosphere
How sensors work
Aerosols
Did the rocket enter the jet stream?   Stratosphere?   How could you tell?
GPS
Barometer
Temperature
Pressure
Jet stream
Does light change with altitude?   Why?
Spectrograph
GPS
Humidity
Temperature
Particulate matter
IMU
Light and atmosphere
Light propogation
Is the sky blue? Why?  Why not?
Spectrograph
Humidity
Particulate matter
Physics
Atmosphere
Did the rocket find air pollution?  What.  Why.  Where.
Barometer
Humidity
TVOC
Particulate matter
Radiation
eCO2
CO
Pressure
Spectrograph
Air pollution
Aerosols
TVOC
CO
Did the rocket see radiation?   If so, where could it come from?  What kind?
Radiation sensor
Particulate matter
Humidity
Pressure
GPS
Barometer
Radiation aerosols
Nuclear physics
Nuclear testing
Nuclear plant failures
Atmosphere science
Mission Software
S4 is based a common satellite mission software package that includes:
For S4Egg and S4Qube this package is written in C/C++ and is hosted on the standard Arduino IDE.
The S4 hardware also support Python for users that prefer to port the mission software to that environment.
The S4 mission software is open source and available for modification and improvement.
S4 Platforms
S4 provides two standard platforms to accommodate different missions.   All platforms are powered by a 3.7V LiPo battery sized for the mission and configuration.   Small configurations, such as S4Egg are powered by as little as 100 mAh, while more robust configurations require 350+ mAh, each delivering hours of operation.
Platform
Package
Processor
Data Storage
Communications
Sensor Capacity
Scope
S4Egg
3D printed plastic package in hen’s egg size, to match TARC payload
ARM Cortex M0+
C/C++
2 MB Flash
None
< 4
Entry level S4 satellite designed to be flown in TARC compatible rockets as a subset of PocketQube
S4Qube
1p PocketQube, 3D printed plastic
ARM Cortex M4
C/C++
22 MB Flash
LoRa telemetry
< 10
Standard Arduino platform with local storage, telemetry and substantial sensor capacity.
S4Egg is embedded in a 3D printed plastic enclosure, in the shape and volume of a chicken egg - 45mm in diameter. S4Egg is based on Adafruit ItsyBitsy M0 Express platform.   It provides an Arduino compatible 48 MHz ARM processor with substantial processing, memory, and I/O resources.   The S4Egg has a standard baseline sensor suite designed for crowd sourced earth science of atmospheric temperature, humidity, pressure, CO2 concentration and Total Volatile Organic Compound (TVOC) measurement.   It has a limited capability for sensor expansion using standard S4 sensor interfaces.   It has no baseline telemetry capability and stores mission data locally on 2 MB of flash.  The platform includes a serial port, a digital/analog port and an I2C port for sensor expansion.
48MHz Cortex M0+ ARM Processor, 256KB program/32KB SRAM memory, I/O, 2MB flash mission storage, LiPo battery management
https://www.adafruit.com/product/2796
$11.95
S4Egg Sensor board
I2C
Serial port
DIO
Environmental
Custom PCB, To be published
~$3.00
Humidity, temperature, atmospheric pressure, equivalent CO2, Total Volatile Organic Compounds sensor
https://www.tindie.com/products/onehorse/air-quality-sensors/
$35.95
150 mAh LiPo battery
https://www.adafruit.com/product/2750
$6.95
3D printed plastic egg enclosure
To be published
~$3.00
S4Egg is programmed in the C/C++ Arduino environment using the Arduino IDE development environment.  The standard S4 mission program can be used to collect data and as a baseline for adding new sensors and experiments.
The S4Qube is based on an enhanced processor platform - the ARM Cortex M4 -  the Adafruit ItsyBitsy M4 Express.  It adds the baseline S4Qube sensors:  flight capable GPS (capable to 80 km altitude), 3d accelerometer, 3d gyro, 3d magnetometer, temperature, atmospheric pressure, battery voltage, equivalent CO2 concentration, TVOC, humidity, UV+IR+visible light intensity, and an 18 channel light spectrometer from 410-940 nm.   The board flash mission memory  expands to 22 MB for local recording of sensor data and a LoRa wireless data connection provides for real-time tracking and telemetry.   The platform includes a serial port, a digital/analog port and an I2C port for sensor expansion.  Like S4Egg, it is programmed with the Arduino IDE and the standard S4 mission software.
The power of the Cortex M4 adds substantial capabilities to S4 - particularly in the areas of imaging and signal processing with a minimal increase in cost.
S4Qube is based on the standard PocketQube 42mm square stackable boards with a common inter-board communications and power bus.   The basic S4Qube can be assembled from two boards - the Processor, Memory and Telemetry Board and the Sensor Board - outfitted with a set of daughterboard sensors designed for the science mission in mind.
There is room for one or more board of similar size within the S4 1p package depending of component height.   Such boards could contain additional sensors or perhaps stepper motors to control a deployable parawing for a controlled, steerable recovery.  An example of such a board could contain the interesting the AS3935 lightning sensor for mapping distance to storm fronts at altitude.
S4 Processor, Memory, Telemetry Board
Custom, open source
120 MHz Cortex M4 w/ hardware floating point processor, 512k program flash, 192k SRAM, I/O, 2 MB flash memory mission storage
https://www.adafruit.com/product/3800
$14.95
LoRa telemetry radio
SPI, u.FL antenna
20 MB expanded mission memory
SPI
LiPo battery + management
Solar cell recharging
Connectors
1Wire bus
S4 Power
S4 bus
S4 Sensor Board
Custom, open source
~$3
Sensors
I2C Mediatek GPS, I2C VEML6070 UV sensor, I2C visible + IR sensor, I2C spectrometer, I2C eCO2+TVOC+temperature+pressure+humidity, I2C acceleration+rotation+magnetometer,
I2C MSLaltitude
Particulate matter PMS- 5003 spectrometer is connected on a QWIIC serial port.
Gamma ray X100-7 radiation spectrometer is connected on a QWIIC DIO port.
Connectors
QWIIC I2C, Serial, DIO
S4 Bus
S4 Imaging Board (Experimental)
Custom, open source
~$3
Sensors
Thermal 32x24 image
Connectors
QWIIC I2C, Serial
S4 Bus
3D printed 1p and 1.5p PocketQube enclosures
To be published
~$3
The third board - the Imaging Board - is experimental.   It integrates two imaging sensors to investigate multispectral imaging.   The first sensor is a simple visible light sensor with the color filters changed to allow capture of the near-infrared.   This allows assessment of ability of plants to process sugar.   The second sensor is a thermal imaging camera.   The board allows for the optional integration of an additional light spectrometer for experiments in ground imaging for vegetation analysis.
Both the Imaging Board and the particulate matter sensor are designed to mounted to the aft outer side of the 1p package to face downward as S4 is deployed for parachute or parawing recovery.
S4Qube is a 3D printed 5x5x5 cm plastic enclosure designed to hold the core processor+memory, baseline sensors, battery, antennas, and additional sensors.  S4Qube can be flown on standard HPR airframes on G thru O motors as a captive payload or can be deployed for independent recovery under parachute.
The core S4 electronics are expected to space capable for short missions to LEO.   It is anticipated that the plastic PocketQube form factor can be upgraded to a 3D printed space capable material and format.
Standard Expansion Interface
S4 defines three external sensor interfaces, each defined a simple four wire interface using SparkFun’s QWIIC 4 pin connector, providing power and data interfaces from sensors to the processor.  SparkFun uses QWIIC just for I2C, but S4 extends it to add a serial port as well as a digital/analog port but adopting a common common miniaturized polarized connector. Standard Arduino C/C++ sensor libraries are shared between S4Egg and S4Qube in the S4 Mission Software.
All of the S4 platforms also support an internal SPI peripheral interface, generally limited to communications and internal storage peripherals and not generally supported as an external sensor interface.
Sensors
The S4 system uses an open ended collection of sensors, on standard hardware interfaces, to measure position, light, dust, chemistry, atmosphere, radiation and multispectral imaging.   The same sensor interfaces are used by all platforms.
The following table represents sensors that can fit in the package, have supported drivers for at least one S4 platform, and are believed to collect useful data during rocket or balloon flight.   Tested drivers for these are contained in the S4 Mission Software.
The list is under continual review as flight experience is accumulated and as new sensors are available and missions are imagined.
Measurement
Sensor
Description/Link
S4Egg
S4Qube
S
O
S
O
Time
Mediatek XA110  GPS
.5 sec with 2 Hz refresh rate.
https://www.sparkfun.com/products/14414
Location
Mediatek XA110  GPS
3m RMS horizontal precision.
Geometric Altitude
Mediatek XA110  GPS
10m RMS vertical precision.
Ambient atmospheric pressure
Measurement Specialties MS5611
Rated to 0 Pa pressure.   Over 100k’ MSL altitude
https://www.tindie.com/products/onehorse/lsm9ds1ms5611-breakout-board/
Bosch BME280
30,000Pa to 110,000Pa  ~30k’ MSL altitude
Ambient atmospheric temperature
Bosch BME280
-40C to 85C
Microchip MCP9808
High precision external temperature
https://www.adafruit.com/product/1782
Acceleration
ST LSM9DS1
3D acceleration sensor.  Up to 16gs.  Software absolute position: roll, pitch, yaw.
Magnetic field
ST LSM9DS1
3D magnetic field sensor.  Software absolute position: roll, pitch, yaw.
Rotation
ST LSM9DS1
3D gyro, rotation sensor.  Software absolute position: roll, pitch, yaw.
Ambient IR light
AMS-TAOS TSL2591
https://www.adafruit.com/product/1980
Ambient Visible light
AMS-TAOS TSL2591
Ambient UV llght
Vishay VEML6070
https://www.adafruit.com/product/2899
CO2
AMS CSS811
Equivalent CO2 detector - 400-8192 ppm
TVOC
AMS CSS811
Volatile organic compounds - 0-1187 ppb.   Ethane, propane, formaldahyde, others
Humidity
Bosch BME280
0 - 100% RH, =-3% from 20-80>#/p###
Lightning
AS3935
https://www.sparkfun.com/products/15276
Spectrometer
AS7265X
18 channel 410-940nm spectrometer
https://www.tindie.com/products/onehorse/compact-as7265x-spectrometer/
Temperature
DS18B20 1-Wire Temp Sensor
Two remote sensors available.
Bosch BME280
40C to 85C
Camera
Still camera
640x480 still camera.  TTL serial interface.
https://www.adafruit.com/product/1386
Updated with false color -
https://publiclab.org/wiki/near-infrared-camera
Particulate matter
PMS 5003
Optical laser dust sensor from .3 micron to 10 micron.
https://www.adafruit.com/product/3686
Gamma Radiation
First Sensor X100-7
PIN silicon photodiode radiation detector.   Detects 0.002-1.0 MeV gamma and X-rays.   Detects photon energy.   Gamma ray spectrometer
https://www.sparkfun.com/products/14209
IR imaging sensor
MLX 90640
32x24 array of IR sensors for IR imaging.  55 degree FOV
https://www.sparkfun.com/products/14844
Communications and Telemetry
An emerging wireless standard for the Internet of things, LoRa, is used as the S4 basis for inexpensive, long range, low power S4 telemetry service in the 902-928 MHz unlicensed band in the Americas.   LoRa is based on a variant direct sequence spread spectrum modulation system that provides up to 30 dB of additional radio link budget depending on desired throughput vs range performance.
The LoRa radio link can be uniquely software configured to trade off range vs throughput.   Low data rate ranges to LEO have been demonstrated.  Telemetry speeds range from 100s of b/s ranging to 10s of kb/s are possible with tradeoffs to range.   S4 uses the standard RadioHead Arduino communications library to provide the basic protocol structure.   S4 uses software tunable LoRa radios in the 902-928 MHz unlicensed band.
The basic S4 ground station is an S4Qube with minimal sensors (just a GPS), attached via a USB cable to a host computer forwarding received telemetry to the host.  The ground station connects to a USB port on a local laptop for a .csv telemetry data stream.   It has a local I2C OLED showing distance and direction to the payload as well forwarding telemetry to host computer for storage.
Documentation
S4 is documented at Hackaday   Current software, documentation and the 3D printer package.
S4 is open source and freely available to be used by anyone - though attribution is a wonderful thing.   We ask that users share missions, new sensors and modifications with the entire S4 community.
Contact Ken Biba at kenbiba at icloud.com for more information.
