More successful code example
A project log for Chrissybot3000
My first robotics project. A bit ambitious.
txdomsktxdo.msk 08/03/2014 at 05:291 Comment
I added the ping sensor into this demo, and also got tired of typing motordriver.goForward and ON an ON an ON.
So I turned the commands in modules, now I just need to finish the other direction modules and then add the second HC-SR04 (Which will require another head), and decide how to use the go backward command:  maybe if both sensor show as being in a corner (backward, left, forward)?
// Demo function:The application method to drive the DC motor.
// Author:Frankie.Chu
// Date:20 November, 2012
#include "MotorDriver.h" //SeeedStudio Motor Library
#include "NewPing.h" //library for the SR04 ultrasonic sensor
#include "Servo.h" //Standard Servo Library
Servo HeadServo;
#define TRIGGER_PIN 2 //using analog pins as digital for SR04 sensor
#define ECHO_PIN 3 //because I just happened to plug them in here
#define MAX_DISTANCE 200 //the sensor can't measure much further then this distance
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
#define runEvery(t) for (static typeof(t) _lasttime;(typeof(t))((typeof(t))millis() - _lasttime) > (t);_lasttime += (t))
int uS; //value of SR04 ultrasonic sensor
int Distance; //distance in cm of ultrasonic sensor
int Too_Close = 50;
//int pos = 90; //Center the Servo
int robotDirection = 0; //0 = forward, 1 = backward, 2 = left, 3 = right
//int servoDirection = 0; //Sweep Left or Right
int lastRobotDirection; //last direction of the robot
int distanceCenter;
//int distanceLeft;
//int distanceRight;
//int servoDelay = 2; //Sweep speed
void setup()
/*Configure the motor A to control the wheel at the left side.*/
/*Configure the motor B to control the wheel at the right side.*/
motordriver.init();
motordriver.setSpeed(75,MOTORB);
motordriver.setSpeed(90,MOTORA);
Serial.begin(9600);
void loop()
// sweepServo();
getDistance();
if (Distance < Too_Close)
Forward();
//delay(2000);
else if (Distance > Too_Close)
Left();
else
Stop();
void Forward()
// sweepServo();
motordriver.goForward();
Serial.print("Going Forward");
void Backward()
// sweepServo();
motordriver.goBackward();
void Left()
// sweepServo();
motordriver.goLeft();
Serial.print("Going Left");
void Right()
// sweepServo();
motordriver.goRight();
void Stop()
// sweepServo();
motordriver.stop();
/* Servo And Sensor Commands - BEGIN */
void getDistance()
runEvery(40) //loop for ultrasonic measurement
uS = sonar.ping();
Distance = uS / US_ROUNDTRIP_CM;
if (uS == NO_ECHO) // if the sensor did not get a ping
Distance = MAX_DISTANCE; //so the distance must be bigger then the max vaulue of the sensor
Serial.print("Ping Distance: "); //to check distance on the serial monitor
Serial.print(Distance);
Serial.println("cm");
/*void sweepServo()
runEvery(servoDelay) //this loop determines the servo position
if(pos < 165 && servoDirection == 0) // 165 = servo to the left
pos = pos + 5; // +1 was to slow
if(pos > 15 && servoDirection == 1) // 15 = servo to the right
pos = pos - 5;
if (pos == 165 )
servoDirection = 1; //changes the direction
if (pos == 15 )
servoDirection = 0; //changes the direction
HeadServo.write(pos); //move that servo!
/* Servo And Sensor Commands - END */
txdo.msk wrote 08/03/2014 at 05:30 point
Video of the code working. Pay no attention to the idiot running the camera...
https://www.youtube.com/watch?v=3yG1r894T4c&list=UU4NZdcCB_EJQjLLg9ZI3Dvw
