it is turning in to a rats nest
A project log for Getting Nibbles to run on a Tandy 1000A
Getting Qbasic Nibbles to run on an IBM Compatible PC, easy rite? Not when the computer is a Tandy 1000A with 128KiB of RAM!
eric-wrightEric Wright 08/05/2014 at 19:560 Comments
I was able to get the two stacks of SRAM jumpered together for all address and control lines that are shared as well as connect the address lines (A0:17) for the SRAM to the card edge connector. Tonight I will connect the AND, ORs, demux, and bus transceiver up and finish wiring the SRAM stacks. This is going to be quite a mess. I really need to invest in some decent wire and stop using network cable. hehe
