usb oscilloscope data logging
Helping the original parallax oscilloscope log data and more
BDMBDM
Helping the original parallax 28014 usb oscilloscope log data and more. I did this project back in 2008 and am now slowly moving my projects over hackaday.io
I have better equipment now but this was my first and cheapest data capturing scope.
I have the original usb oscilliscope from parallax and was attempting to do some logic decoding however I could not press print screen fast enough or even enough times to capture a complete message.
I knew the scope had a usb to serial chip so I thought I could intercept the messages and build my own graph with a complete start to finish picture.
  • 1 × Parallax V1 (82014?) USB oscilloscope Maybe ebay now, it has been replaced with a better model
  • 1 × Portman software from MS Any port monitoring software would work
  • 1 × .NET A programming language
  • 1 × ZedGraph was free back in the day for .net simple graphing
  • More bad news
    BDM08/05/2014 at 01:33 0 comments
    I can't use PortMon on Windows7...  I'm forced back to original software that cant log worth anything...
  • Trying to find the source code
    BDM08/02/2014 at 15:41 0 comments
    It's been 7 years and I am having trouble locating the source code.  I found the install package and will get it uploaded first while I continue searching for the original code.  If not I hope I didn't obfuscate and can reverse easily.
  • First logic view
    BDM08/02/2014 at 15:22 0 comments
    New Logic program that logs ALL data from scope output with PORTMON
    THESE ARE NOT THE SAME OUTPUTS, JUST SOMETHING TO COMPARE VOLT/LOGIC
    Partial view from Parallax scope app
    Made a couple of basic parameters for the app named, Input Voltage Low (Vil) , Input Voltage High (Vih) , and finally Input Voltage (Vcc) variables. If the 30/70% of Vdd rule is exceeed the value is changed to a 1 or 0 giving a stepped logical view instead of scope type of view with little voltage spikes and dips.
  • Hex code decyphered, time to program
    BDM08/02/2014 at 15:21 0 comments
    Here is a SS of the hex --> voltage chart. Simple pattern after the first .07. It is (5) .08 tehn a .07, all the way to the end.
    I am in the processing of putting togethor a simple VB.NET with zedgraph component to read the output from PORTMON and plot it on a graph and if time permits ultimatly automaticall decipher the I2C messages.
    App will be able to read the PORTMON data log file, look for the pattern of 55, data1, data2, AA and if all is valid (not more than 2 data sequences between the 55 and AA) output the data to a graph. The output captured from the scope is 50uS at 5V for both channels. Will also prob add in a logic mode that will use a couple of params at first to determine what is considered "HI" and "LOW" so it's not a voltage reference chart.
  • Portmon to the rescue
    BDM08/02/2014 at 15:20 0 comments
    Well Portmon was able to capture all the messages sent/received to the oscilloscope, looks like data is sent. I setup a filter to include only IRP_MJ_READ and IRP_MJ_WRITE message types only. Here are the "good" messages that need to be deciphered or at least understood as a pattern.
    ******** SEND DATA REQUEST START ******
    IRP_MJ_WRITE Length 1: AA
    IRP_MJ_WRITE Length 1: 52
    IRP_MJ_WRITE Length 1: F3
    IRP_MJ_WRITE Length 1: 14
    IRP_MJ_WRITE Length 1: 00
    IRP_MJ_WRITE Length 1: 91
    IRP_MJ_WRITE Length 1: 07
    IRP_MJ_WRITE Length 1: 2D
    IRP_MJ_WRITE Length 1: 05
    ******** SEND DATA REQUEST DONE ******
    ******** RECV ???ACCEPTED CMD??? ******
    IRP_MJ_READ Length 1: 55
    ******** RECV DATA FROM SCOPE START ******
    IRP_MJ_READ Length 1500: 7E 7E 7E 7E 7E 7E 7E 7E 7E .... (ch1 data)
    IRP_MJ_READ Length 1500: 7E 7E 7D 7E 7E 7E 7E 7F 7E ....(ch2 data)
    ******** RECV DATA FROM SCOPE END ******
    Above sequence loops until "STOP" button is pressed which shows up as a
    IRP_MJ_WRITE Length 1: FF
    Will decypher the data section tomorrow and post an excel file of results.
  • scope can't handle it
    BDM08/02/2014 at 15:19 0 comments
    Well the oscilloscope does not do any data logging and only captures what is on the screen.  Not being able to log  data is real limitation.  I see the data flash on the screen but can not capture the entire data steam as an image or as a saved data file. Since it's USB probably has some USB --> Serial chip inside. Time to see what can be done to fix my needs w/o buying another scope.
View all 6 project logs
mabelgoodrich wrote 02/15/2021 at 17:38 point
Thanks for sharing this command! These statistics and graphical presentation let us know-how is the project about! Your project details especially coding system encourages the new generation of designers. Most of the people like to have enjoy and get engaged with their soulmate in online platform like as https://mega.porn/ since there are more than an individual thinks about his partners. They have a large group of profile for men who like sexy women for having sexpartner around the world!
