First logic view
A project log for usb oscilloscope data logging
Helping the original parallax oscilloscope log data and more
BDMBDM 08/02/2014 at 15:220 Comments
New Logic program that logs ALL data from scope output with PORTMON
THESE ARE NOT THE SAME OUTPUTS, JUST SOMETHING TO COMPARE VOLT/LOGIC
Partial view from Parallax scope app
Made a couple of basic parameters for the app named, Input Voltage Low (Vil) , Input Voltage High (Vih) , and finally Input Voltage (Vcc) variables. If the 30/70% of Vdd rule is exceeed the value is changed to a 1 or 0 giving a stepped logical view instead of scope type of view with little voltage spikes and dips.
