Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Pet Fire alarm
This project will open the doors to your home once the fire alarm goes off. this will allow your pets to escape.
RoboPandaPDXRoboPandaPDX
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 4
202
4
6
1
Team (1)
  • RoboPandaPDXRoboPandaPDX
Join this project's team
arduino iot xbee alarm Fire safety automated smoke pets animals ioe save lives doors
This project was created on 08/02/2014 and last updated 8 years ago.
Description
This project will open the doors to your home once the fire alarm goes off. this will allow your pets to escape. Smoke inhalation is also a big killer in fires. Maybe allowing the house to vent the smoke, will give the occupants a few extra minutes to get out. This will also decrease the amount of smoke that can fill the house at once. allowing personel and animals close to the ground to be able to see and breath to get out.
Project Logs
Collapse
  • The Idea
    RoboPandaPDX • 08/02/2014 at 17:16 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
RoboPandaPDX wrote 08/03/2014 at 07:20 • point
Yeah it's called a backdraft. I believe it happens when a fire has used up most of the oxygen in the room and just kind of lays dormant like coals in a campfire and then when oxygen is intoduced there is an explosion due to the fire being fed oxygen at an alarming rate. Some say you hear a whistle as the air rushes in and then the explosion. Hopefully this opens the house to air prior to that condition and allows all living occupants to get out safely. I will have to do some serious research into fire situations in a home to dial in this invention. Great comment Dave thanks.
davedarko wrote 08/03/2014 at 07:53 • point
It's awesome of you to be thoughtful of your pets and I hope you come up with something safe :)
davedarko wrote 08/03/2014 at 06:26 • point
Wouldn't an open door mean more oxigen for the fire to burn faster? I remember seeing in a documentation that in some cases an explosion was triggered by opening a window because of the sudden extra air flow.
[deleted]
davedarko wrote 08/03/2014 at 06:23 • point
Then in it is extra easy for her to leave the house in shame :D
An open-source robotics project for learners of all ages
Project Owner Contributor
The Barnabas Navigator
Edward LiEdward Li
This project is IOT based project, this project demonstration is on MY Youtube channel: Udhaya Tech inventor
Smart junction box
udhayasuresh20udhayasuresh20
The platform allows a home automation system to be programmable by customizing events and triggers.
Workflow-Based Platform for Home Automation
Chris AmanseChris Amanse
An Open-source Cryptocurrency Project
CryptoCRIT
Abhishek ChaudharyAbhishek Chaudhary
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "Pet Fire alarm", please tell us the reason.
Send message
Remove Member
