HP 5082-7356 display watch
A digital watch , which uses vintage , military grade HP 5082-7356 displays.
Not long ago I stumbled upon a batch of vintage HP 5082-7356 displays. Those magnificent devices from the 80-ties , encased in glass - ceramic cases with built-in decoders deserved to be used again , so I built a watch with them.
The displays require a lot of power . Even when dark , the driver chip in each display consumes almost 0.5W . To keep with it the watch uses a LiFePo cell ( the size of AAA battery , housed in the round part of the watch ) and the high efficiency DC-DC converter. The heart of the watch is the STM32F051 MCU , used both as the RTC and as the display controller.
The case of the watch was milled from the block of aluminum and then anodized black .
The video of the completed watch can be found here :
https://www.youtube.com/watch?v=GPfjgoj_oyM
watch_src.tgz
Watch firmware source
x-compressed-tar - 5.92 kB - 05/20/2017 at 20:16
Download
watch.bin
Watch firmware
octet-stream - 2.98 kB - 05/20/2017 at 20:13
Download
watch.zip
GERBER files of the watch PCB
Zip Archive - 37.40 kB - 05/20/2017 at 20:12
Download
watch_schem.pdf
Schematics of the watch
* - 18.03 kB - 05/20/2017 at 20:11
Preview
Download
