MIDI light controller will take MIDI output and translate into a light show display.
Initially this will be developed using a Roland drum kit but should translate to any device with MIDI output.
To start, each MIDI value will be mapped to a light controller, but this may be expanded later so that "chords" or multi-note output from the MIDI controller will trigger other lights or sequences.
The basic goal is to control a light show based on the drum beat.
