Acquired most of the parts needed
A project log for Desktop CNC Mill Conversion
Mill conversion with only salvaged components
tecratalTecratal 08/05/2014 at 19:180 Comments
So far I am off to a good start. I have salvaged all the power supply, motors, drivers, belts, pulleys, and metal I will need. I still need to find some optoisolators to go in between the computer and the driver IC.
I don't want to make any permanent modifications to my mill. That way I can still use it to make parts. So my first step is to begin machining a new part that holds the toothed pulleys onto the shaft of the lead screws.
