New calibration print.
A project log for MDFStrap 3D Printer made with MDF
From slow single hotend semi accurate 3D Printer to fast and accurate dual hotend 3D Printer.
terry-batesTerry Bates 08/17/2014 at 21:010 Comments
I have created a calibration print for use in calibrating settings in the marlin firmware, this files is available on my github, its pretty basic but easy to use, there is 15cm between the cuts as shown in the image below, measure this with calipers if its incorrect you can adjust and reprint.
