Features:
- STM32F10x controller with hardware USB 2.0 FS
- Rotary encoder ( quadrature output )
- Rotary switch ( 7 position )
- Switch button
- NOKIA 5110 LCD 84x48 [PCD8544]
- 1.8' TFT 128x160 [ST7735R]
- EastRising ERC12864-4 COG LCD 128x64 [ST7565R]
- 20x4 LCD [HD44780]
- Matrix keyboard ( up to 5x4 )
- Emulate L(W)HB04 and L(W)HB03 MPG
- Supports official plugins for Mach 3 and NCStudio
- Can build firmware with IAR ARM, Keil 5.x, CooCox 2.x, GCC
Links:
- Alpha version YouTube video
- Mach 3 plugin ( ver. 3.5.8 ): Download
- NCStudio plugin ( English, ver. 1.2 ): Download
- Linux CNC HAL ( ver. 0.6 ): Download
- XHC Company Web
TODO:
- Add more LCD
- Code clean-up
- Wireless version
- Open-source hardware PCB board
Moonglow
By August 20th you must have the following:
- A video introducing your project that's less than 2 minutes long. Put it on YouTube (or Youku), and add a link to it on your project page. This is done by editing your project (edit link is at the top of your project page) and adding it as an "External Link".
- At least 4 Project Logs
- A system design document
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information.
You should also try to highlight how your project is 'Connected' and 'Open' in the details and video.
There are a couple of tutorial video's with more info here: http://hackaday.com/2014/07/26/4-minutes-to-entry/
Good luck!
