Toner Transfer with Kapton
Back to overview
Kapton tape on printer paper makes for super easy and effective pcb trace transfers.
mosaicmerc wrote 04/18/2015 at 18:22 point
I can't see the advantage of this over magazine paper, which is free and works well.
Note this:
https://hackaday.io/project/3363-apache-al13p-laminator-one-pass-pcb-toner-xfer
SUF wrote 02/23/2015 at 14:20 point
Hi
I tried this out, but the result was a disaster. The image appeared on the board was useless:
Do you have any idea, what I'm doing wrong?
Thanks,
Zoli
James Newton wrote 02/23/2015 at 20:55 point
The PCB doesn't appear to be clean. It has to be very, very clean and no residue on it at all. Use Isopropyl alcohol and a clean cotton rag or paper towel as a last step.
SUF wrote 02/24/2015 at 13:27 point
Thanks, I'll try this. My cleaning process was good enough for the normal toner transfer. It looks not good enough for the kapton.
Greg Fenton wrote 08/08/2014 at 08:20 point
This is great :)
Would you mind if I added it to our makerspace howto page?
